Guys, I have this external case and power supply (see below). I forgot I had it and guess I can use it for my external 5.25" bay and external power supply (from another post). The problem is I can't find what the wattage is of the power supply in it. The sticker states "100/240VAC 2.0A" which Ohm's Law tells me it would be 200 watts @100v, and 230 watts @115v. This sounds like a lot for just a SCSI HD, although it is one of those massive 10lb full height boat anchors. I don't know if I should go by that sticker, and THAT figure is the REAL wattage, or take readings from the 12v and 5v lines and go by them. 12v is 4.2A and 5V is .8A which is only 50 watts on the 12V line. So, is this a 50 watt PS or 200 watt PS?
I wanted to use the PS to power some devices since I think my PC"s main PS is going to be choked a bit. This device would be great since I can't find any external AT PS enclosures and I need an external 5.25" bay anyway for an audio EQ.
Here and here are some images and I pasted the info they give below:
** External 9.0GB SCSI Hard Drive **
- Drive Model Seagate ST410800N
- Formatted Capacity of 9,090 MegaBytes
- Internal Transfer Rate 44-65 mbits/sec
- External Burst Transfer Rate of 10 mbyte/sec
- 5400 rpm Spindle Speed
- 5.5 ms Average Latency
- 1024 Kbyte Read Look-Ahead, Adaptive, Multi-Segmented Cache Buffer
- 11ms Average Access Time
- Preinstalled into a ROCK SOLID External SCSI Case
- Selectible SCSI ID
- Heavy Duty Fan
- Case is UL, CSA and TUV approved
- External Connector is HD (High Density) 50 (aka: Micro DB50 - Female) w/passthrough
- Case size is 13 x 9.25 x 5.5 inches (L x W x H)
- PC and MAC Compatible
- NEW (case) and Refurbished (Drive), w/power cord
- External Case has NO FACE-PLATE BEZELS
High-Capacity, High-Performance, Full-Height
Narrow SCSI-2 disk drive with 9.09GB of
formatted capacity, PRE-INSTALLED into a high
quality External SCSI Case!!!
Thanks.
- Heavy Duty Fan
Thanks.
