How to find out what's using up CPU resources? (Task Manager not too helpful)
tracerit
Temp on idle is usually 35-40C but sometimes it'll jump up to 45C and stay there. I keep my desktop on 24/7 and overnight it was at 40C but when i started using it for about two hours today then left home, I came back and noticed it was still at 45C and steady. Checked Task manager and nothing was excessively taking up space. I rebooted to make sure it wasn't just the day's temp, and after rebooting it now idles back at 40C.
I'm thinking there's a rogue program or process eating up resources, but I can't figure it out. Just wanted to get some ideas but in the mean time I'm going to try to single out some programs to see and if it's somethign I can reproduce.
It could be voltage related. Your idle voltage is probably swaying back and forth for some reason, which CAN happen if you have system tray or background apps open.
What I would do is keep an eye on idle voltage levels when this happens. Voltage goes up = CPU temps go up. Even if your CPU usage has not changed, this still applies. If you have 5% CPU utilization with 1V versus 5% CPU utilization with 1.25V, temperatures go up and go up fast. Use CPU-z to keep an eye on it.
You could try Resource Monitor. I believe that it also shows system services that are running (at least with admin privs) - that could help rule out an errant process.
I'll check out REsource MOnitor and Process Explorer. Thanks for the links! I"m currently using OpenHardwareMonitor now to monitor the history of my temps, when I pulled up the voltage, it seems 24 hours (max history) has passed so I no longer have the values when the temps were lower.
It wasn't the noon tempt because after I rebooted, everything went back down to normal.
It wasn't just the noon-time temp increase from the Sun, was it?
This would be my guess. A combination of higher ambient temps and the hsf getting a little dirtier.
I don't think it's task manager isn't helpful, I think that you're chasing ghosts trying to find a resource hogging program that likely doesn't exist. Not to mention, the difference between a loaded and idle CPU is a lot more than 3-5 degrees.
I don't think malware is the issue either, but some software/hardware malfunction might be enough to keep the CPU from entering sleep states properly.
If I were the OP I would just keep track of the system, log some data (temps for example). If this is a real problem, symptoms will repeat.
If you are in the processes tab, and tell it to show processes for all users, what application(s) are showing the highest number(s)?
For example, as I type this in my VM, the highest number I am seeing is Firefox, and it is jumping between 00 and 06.
It might be a hardware issue.
Have you opened the case and cleaned out any dust that might be causing a cooling fan to stall out occasionally?
