How to find out if my CMOS battery needs replacement?
Mir96TA
1,950
37
Low CMOS Batter Error at Post
if stated losses Bios Setting
or you can run HWMonitor and look for 3VCC if it is below 3.2; then you need NewBatter
virtuality
138
max347
2,335
Post is when your computer turns on and the system checks itself basically, when the black screen with all the info comes up.
vailr
54
If there were actually a CMOS battery failure, the system date would default to an earlier date & clock setting, after power is shut off.
Although: with a laptop, you may need to disconnect the main system battery in order to see accurate results.
Mir96TA
1,950
37
Compman55
1,241
1. Buy a cheap votage metdr from harbor freight. Everyone needs to own one.
2. Measure the battery using DC voltage.
3. Replace if below 2.5v It should be 3.0 to 3.3 brand new.
Vinwiesel
163
We have a computer at work that started saying something like "cmos error, loading defaults" when rebooting. This is an original pentium 386, and the battery is probably original as well.
It doesn't have to be old to be bad though. The minimum-wage and/or 3rd world assemblers are known to dump trays of new batteries into piles, or loose in bags and short them out to each other. I suspect this may be why some computers use a battery that is encapsulated with a cable.
virtuality
138
Thanks, very helpful. [Not, really.] I could find out discussion with Google but nothing else relevant. Maybe a direct link to the solution? Would be helpful.
But I'm also not sure if I need the basic or the Pro, free or paid version of HWMonitor? Couldn't locate the documentation of the software.
virtuality
138
Thanks, actually that was useful, I'll do that. Expect that I don't have a Harbor Freight, I'm not from Mexico. ;)
virtuality
138
OFF:
I put my X60 into sleep, there was no main battery in the machine and the power cable also came off. To my surprise, when I plugged in again, Windows did not start again but resumed. So it seemed the backup battery can also power the RAM in sleep mode (but for how long?).
Rebellemm
Normally when the computer stops holding the correct day/time it indicates the CMOS battery is bad. If it is a desktop, a new cmos battery can be purchased for about $3. It is easy to replace, about the size of a nichel, and is sold at any local drug store or convenience store in the battery section. They last maybe 3-5 years then need to be replaced.
NickelPlate
652
13
If there's any doubt just replace it, they're really cheap and not worth the time IMO wondering whether they're good or not.
You can get a card of five of them on ebay from hong kong shipped for 99 cents lol.
