what program are you trying to use, and what make/models are these cards? are they reference or otherwise? what bios are they using?
Hmm, not an expert on those cards, they might be voltage locked I do not recall. Or trixx/afterburner is not set up in a mode to OV them. There may be a tweak you have to do with trixx and afterburner to enable voltage control, I don't remember. Or you may need to flash a modded bios that enables voltage control, if one exists.
Perhaps someone with more experience in these could help you further 😀
Looks like you've enabled everything you'd need to. Does voltage control work with just one card installed? What version of Afterburner are you using?
Afterburner won't allow voltage control on my vanilla 7970 FLASHED to ghz edtion. The option is greyed out no matter what even if I do -xcl. Sapphire Trixx however has no problem at all allowing for voltage control. Have you tried Trixx?
edit...
Just reread and saw that you have tried trixx.. I'm out of ideas
If your cards have the bios switch I would just try flashing to another bios. With the back up bios you have nothing to lose.
If you can, I would seriously look into the ASUS GPU Tweak application. It isn't as functional as afterburner, but it does work to change voltage on cards that I otherwise could not get to change. Also in Trixx did you disable ULPS?
Watch your temps carefully, I had a 6950 flashed to a 6970 and with the reference cooler the card stayed so hot that I ended up flashing back to 6950 with unlocked shaders.
