how to enable HYBRID CROSSFIRE with AM3 Processor with HD7750?
SPBHM
5,076
440
only very old and slow cards can CF with the 760G (HD 3000), like the HD3470.
with your 7750 it's impossible,
NTMBK
10,521
6,037
That card is much newer than the graphics processor on your motherboard, and is based on incompatible technology (Graphics Core Next). You can't combine the two. Don't worry though, you're not missing out on much- Hybrid Crossfire was always a stuttering mess.
KingFatty
3,034
Hybrid Graphics::
With the AMD Hybrid Graphics technology for a power boost. You'll additional performance from your AMD 760G chipset when paired with a Radeon HD3450 graphics card. Hybrid graphics is not possible with other cards.
Your HD 7750 discrete video card is way way better than the motherboard integrated graphics. I would suggest disabling the on-board video altogether, and don't worry about trying for hybrid (in fact, even if you could somehow get it working, it would simply downgrade your experience, since the HD 7750 is so much better.
Also the reviews that mention your AMD 760G chipset also mention it paired with a 7750, but that is an *ATHLON CPU* 7750, and not the video card HD 7750, so maybe that's where the confusion comes from?
