You need to set up simple file sharing. You can do that by right clicking a folder you want to share and going to sharing and security. From there, select the option to share the folder, you can give it a share name different from the folder name if you'd like, and then you need to select who has access to the share. If you're not concerned about security, you can give the Everyone group full control and that will let you read and write to it from any computer. If you are concerned about security, you can just set up read access to the Everyone group for that folder. If you're really concerned about security, you'll need to create a new user (or group) on the host computer where the share exists and give that user (or group) the permissions you wish them to have. Then when you access the folder over the network you'll be prompted for a username and password and you can enter the credentials you set up for the new user.
