How to do Bit masking in C++?
IkarusDowned
So, i want to mask a certain number of bits in, say, an integer. How do i do that using another integer variable? Like, i want to mask the number of bits in int bit_mask and i was to mask the value int masked_number. I haven't found a good explaination or anything on how to do that. please help!
// use xor instead of and to clear bits instead of keep bits
int x = v & 0x00f ; // mask to only inlcude lower 4
int x = v & (1 << k) ; // mask just single bit k,, k = 0-31 for int
int x = v & ((1 << n)-1) ; // retain lower n bits, n = 1-32 NOT 0-1
That's only if you know for sure the bit is already set. The easiest way is just to and with the bitwise inverse...
//clear lowest bit
int x = v & ~0x1;
//set lowest bit
int x = v | 0x1;
d'oh! correct. AND to keep, OR to set, AND of inverse to clear.
to clear bits
int x = v & ~ (the bits to clear)
such as
int x = v & ~ (1 << k) ; // clear bit k where k = 0 - 31
