I've used tape backups for the past 8 years but my tape went bad, and I needed a drive with a larger capacity (mine was only 8 gigs). It's hard to get travan tape drives, so I've decided to backup to CD-RW, a Plextor 24x10x40 which I just got last month so I'm a newbie with CD-RW.
I ghosted my hard drive on CD-R. Now I need to know how to do regular backup of files on CD-RW. With tape drives, you backup the whole drive, then set it to backup new/changed files, and you can set it do backup automatically every day at a selected time.
So how is this done on CD-RW? What software should I get or can I use the software that came with the Plextor? Can it be set to automatically backup new/changed files?
