- Jan 5, 2010
- 166
- 41
- 101
I'm trying to select suitable RAM for a Gigabyte B550 motherboard and 5600X CPU. I'm gravitating towards G.Skill Trident Z RGB RAM because I'm a G.Skill fanboy (not really, but all I've ever purchased has been Ripjaws). I'm also going for 2x8GB @ 3600 MHz CL16 because Steve from Hardware Unboxed said it's the sweet spot for the Ryzen 5000 CPU.
I'm hitting a few roadblocks because I have never been on AMD before and it's been six years since I last bought RAM.
1. The RAM Configurator tool does not return any 3600 MHz kits when I input my mobo/chipset! The fastest kit displayed is 3200 MHz CL14. 🤨
2. When manually searching for RAM, I have the option between "Trident Z RGB" and "Trident Z RGB (For AMD)". If I picked "for AMD", none of the RAM shown is 3600 MHz CL16! 🤨
3. As if this was not enough, when I just look for Trident Z RGB or Z Neo, I'm offered two options at 3600 MHz CL16! This is so complicated... I don't know what to buy!
I'm lost. Wonderful community: "help!"
