How to determine right memory for a motherboard
millervt
13
I recently got a barebones kit that included the PC CHips A13G+ GEforce6100 motherboard, along with 1 GB of slow pc4200 memory. I want to upgrade the memory, but I get confused when I go to newegg and find all kinds of nearly-identical 1GB offerings (I'm looking at 2X1GB of dual channel PC6400 as a good "sweet spot" for my budget). However, when I go to corsair, patriot, etc., and try to find the motherboard so I can confirm which exact memory part number is compatable, it isn't shown. Should I just get one set of sticks and assume that I can make it work at some sort of settings? Of course the PC CHips/ecs web site has nothing very specific on it (supports up to 800mhz dual channel ddr2...). Thanks for any suggestions..
Steve
15,945
11
Try looking up the ECS equivalent, either the ECS GeForce6100SM-M (V1.0/1.0A) or the GeForce6100SM-M2 (V1.0A)
Mondoman
356
miller - depending on your CPU, PC2-4200 (DDR2-533) may be plenty fast. Unless your CPU is running a 1333MHz FSB, you won't really be able to use the speed of faster RAM. Assuming your 1GB is 2x512MB running in dual-channel mode, at DDR2-533 speed its datarate is 1066MHz, which is enough to saturate the throughput of either an 800MHz FSB (e.g. e2xxx and e4xxx CPUs) or a 1066MHz FSB (earlier e6xxx CPUs).
For buying new RAM, the key thing is to make sure to buy RAM rated at the DDR2 standard 1.8V. Many manufacturers sell "pre-overclocked" RAM requiring voltages as high as 2.2V -- these are *much* more likely to have compatibility problems with lower-end chipsets such as those on your MB.
