Easy way could be to hook up the analog stereo out from your live tv source to the amplifier for the paging system and pipe it through those speakers. You could get an input or speaker selector to make it easy to switch back to the telephone/paging system.
This is assuming it's the standard paging setup I'm familiar with. Might have to look in your office's "data closet" or whatever you have. Often times it's a Realistic amplifier hooked up to your phone system.
