hi, I have an enermax E-365-P-VE (350 watt's 2 fans, not themally controlled)
and I'd like to replace these two fans with Pabst fans (because these are quiter and I dont like the noise)
but I know the PSU keeps a lot of power within it's capacitators, so how do I remove that charge from the capacitators ?
can it be done by waiting for the power to drain (and if it can be done, how long would it take ...)
and another note .. does a PSU dissapate less heat when the system is inactive ? because then I can switch those fans to 7 volts when I go to bed (would shave another few decibels off the sound ...)
and would it be damaging to the PSU if I replaced the fans with lower CFM rated fans (cous pabst dont really have a high RPM
the rest of the system will not dissapate much heat because it will be watercooled and there R four intake fans ....
