- Jul 11, 2001
- 40,904
- 10,228
- 136
I have a 6" x 12" piece of stainless steel that's 0.012" thick that I need to cut without it deforming. I think that equates to 30 gauge.
When I bought it at a large hardware store, I talked to the guy servicing me and we figured I could use my aviation snips but now I'm thinking that the metal will deform if I use that after marking the straight line I want to cut on. I also have a steel sheet metal shears, but it doesn't have the mechanical advantage of the cheap aviation snips I bought at Harbor Freight some years ago.
I have a tungsten carbide scribing tool I used to good effect to cut some Hardie Planking last summer. Can I use that to scribe deep scratches on both sides and try to bend the metal back and forth until it breaks? Or is there some other method I can use? I have a bench vise and a wood vise, too. I could use them to grab the scored plate held between wood strips to prevent scratching.
