Why in the world are you creating a cue file? When you create a CD image (with a program like CDRWin), it'll create a .BIN and a .CUE automatically. You may need to edit a .CUE file but never create it from Notepad for some strange reason.
i had a bin file last night, so i edited another cue file to try to burn my bin... burned 2 coasters twice..turns out the original cue was for mode1 instead of mode2/2325 whatever >😱
