MichaelD
I have my HTPC hooked to my receiver with a coaxial cable via the motherboard's SPIDF-out.
I control the HTPC with a wireless KB/MS. (Yes, I've loaded the software that came with it 😉) The KB has volume control buttons and when you press them, you see the OSD and the volume bar moves up and down, but the actual volume does NOT go up and down.
I'm assuming that this is b/c the volume control is somehow "mapped" to the analog outputs and not the digital?
Is there a fix for this? It would be cool to be able to change songs and control the volume, both w/the KB. 🙂
