I just ordered a CM Hyper 212 EVO and have a spare 120mm fan sitting around. If I add that for use in a push/pull configuration, is it important that the puller matches the speed of the pusher? If so, since the pusher is PWM, how do you control the 2nd fan to match?
Are there multiple PWM fan controllers on the boards? Or just the one CPU fan controller?
This is the board I ordered:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
(ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68)
