Hi,
I got
/usr/local/tomcat5/webapps/Advanced/connect.jsp
<html>
<head>
<title>Connection Test</title>
</head>
<body>
com.wrox.library.Connect con = new com.wrox.library.Connect();
con.init();
<h2>Connection Result</h2>
<%= con.getstat() %>
</body>
</html>
/usr/local/tomcat5/webapps/Advanced/WEB-INF/classes/com/wrox/libraryConnect.java
package com.wrox.library;
import javax.naming.*;
import javax.sql.*;
import java.sql.*;
public class Connect {
String stat = "Not Connected !!";
public void init() {
try {
Context ctx = new InitialContext();
if(ctx == null )
throw new Exception("Oops - No Context");
DataSource ds = (DataSource)ctx.lookup("java:comp/env/jdbc/BooksDB");
if (ds != null) {
Connection conn = ds.getConnection();
if(conn != null) {
stat = " Got Connection "+conn.toString();
conn.close();
catch(Exception e) {
e.printStackTrace();
public String getstat() {
return stat;
/usr/local/tomcat5/webapps/Advanced/WEB-INF/web.xml
<?xml version="1.0" encoding="ISO-8859-1"?>
<!DOCTYPE web-app PUBLIC
"-//Sun Microsystems, Inc.//DTD Web Application 2.3//EN"
"http://java.sun.com/dtd/web-app_2_3.dtd">
<web-app>
<description>mySQL Test App</description>
<resource-ref>
<description>DB Connection</description>
<res-ref-name>jdbc/BooksDB</res-ref-name>
<res-type>javax.sql.DataSource</res-type>
<res-auth>Container</res-auth>
</resource-ref>
</web-app>
/usr/local/tomcat5/conf/server.xml
<Context path="/Advanced" docBase="Advanced" debug="5" reloadable="true" crossContext="true">
<Logger className="org.apache.catalina.logger.FileLogger" prefix="Wrox_Advanced_log."
suffix=".txt" timestamp="true"/>
<Resource name="jdbc/BooksDB" auth="Container" type="javax.sql.DataSource"/>
<ResourceParams name="jdbc/BooksDB">
<parameter>
<name>factory</name>
<value>org.apache.commons.dbcp.BasicDataSourceFactory</value>
</parameter>
<!-- Maximum number of idle dB connections to retain in pool.
Set to 0 for no limit.
<parameter>
<name>maxActive</name>
<value>100</value>
</parameter>
<parameter>
<name>maxIdle</name>
<value>30</value>
</parameter>
<parameter>
<name>maxWait</name>
<value>10000</value>
</parameter>
<parameter>
<name>removeAbandoned</name>
<value>true</value>
</parameter>
<parameter>
<name>removeAbandonedTimeout</name>
<value>180</value>
</parameter>
<parameter>
<name>logAbandoned</name>
<value>true</value>
</parameter>
<parameter>
<name>username</name>
<value>booksuser</value>
</parameter>
<parameter>
<name>password</name>
<value>bookspass</value>
</parameter>
<parameter>
<name>driverClassName</name>
<value>org.gjt.mm.mysql.Driver</value>
</parameter>
<parameter>
<name>url</name>
<value>jdbc:mysql://192.1.3.139:3306/books?autoReconnect=true</value>
</parameter>
</ResourceParams>
</Context>
</Host>
</Engine>
</Service>
</Server>
The above is to connect to MySQL database. How about if I wanna connect to MS Access DB ? How should I change the above code and setting or configuration ? Where should I put the MS Access file ? Thanks !!!
I got
<html>
<head>
</head>
<body>
con.init();
</body>
</html>
import javax.sql.*;
import java.sql.*;
try {
if(ctx == null )
if (ds != null) {
if(conn != null) {
conn.close();
return stat;
<web-app>
<resource-ref>
</resource-ref>
</web-app>
<parameter>
</parameter>
<parameter>
<value>100</value>
</parameter>
<parameter>
<value>30</value>
</parameter>
<parameter>
</parameter>
<parameter>
<value>true</value>
</parameter>
<parameter>
<value>180</value>
</parameter>
<parameter>
<value>true</value>
</parameter>
<parameter>
</parameter>
<parameter>
</parameter>
<parameter>
</parameter>
<parameter>
<name>url</name>
</parameter>
</ResourceParams>
</Context>
</Host>
</Engine>
</Service>
</Server>
