How to connect MIDI to SB Audigy 2 ???
draazeejs
19
Hi!
I would like to know one thing - I am going to upgrade from my SB-Live card to SB-Audigy 2, non-platinum card.
At the moment I can connect my music synthesizer to my sound card via the gameport-MIDI extension.
The Audigy 2 does not have neither MIDI connectors nor game-port. Are there any ways around this?
Please help. I do not want to buy the expensive card with the front panel...
Thanx a lot.
chilled
709
I'm sure that (at least the non-ZS variant of) the Audigy 2 has a gameport via a separate PCI plate that plugs into the card's PCB using a ribbon cable.
Demo24
8,356
9
yeah I got a plain ol audigy 2 and it came with a game port that you plug into it and put it in a case PCI slot enxt to it
draazeejs
19
Thanks, do you know if the Audigy 2 ZS also comes with that game port add-in card???
chilled
709
If you don't get any responses or are in a hurry, Google for some reviews and see if they have any pics. Maybe Newegg has a few pics as well.
