How to connect front USB ports
BadThad
12,100
49
How do these match up for connecting the front case USB ports?
There are 4 cables going to the USB connector on the front of the case, there are labeled:
USB+
V
USB-
G
On the mobo they are labled:
USB +5
LDM2
LDP2
GND
I know these match-up:
USB+ TO USB +5
G TO GND
I don't know about the other 2. Any help is appricated.
BadThad
12,100
49
ahhh...that doesn't really help me, thanks anyway. The mobo is an Asus P4T533.
BadThad
12,100
49
ahhhh
Looks like this is the answer:
USB+ >> USB +5
G >> GND
LDM2 >> V
LDP2 >> USB-
Can anyone confirm this? I'd hate to toast a USB device, it's a bit tricky because of the power flowing thru.
Thanks
Kartajan
1,264
38
my translation:
USB +5= 5V in-------------->>V=Power
LDM2= Line Data Minus-->>USB-=- signal/ Data
LDP2= Line Data Plus---->>USB+=+Signal/ Data
GND+ Ground------------->>G=Ground
morkinva
3,656
Originally posted by: Kartajan
my translation:
I agree with this interpretation
TheCorm
4,326
Originally posted by: VicodiN
Not meaning to sound like a prick, but didnt you get a manual with ya mobo?
I've found that often the case manufacturers and motherboard manufacturers labelling doesn't tie up...as in this case.
Rav3n
209
I think it might be fun to see a USB device burn.. I mean... go for the translation above, it makes a lot of sense. The other thing though - in my experience I have never had a problem with the connectors because of the way they are usually oriented - couldn't screw up even if I tried - if thats not the case (and I assume not) then definitely go with what has been mentioned.
BadThad
12,100
49
my translation:
Seems logical....thanks!
BadThad
12,100
49
I've hooked up thousands of USB cables, but all the wires were on one connector. In this case, each wire is an individual. One mistake and you can fry a device.
BadThad
12,100
49
