Ok, I thought I understood this stuff, but now I find myself confused and disoriented (without the alcohol this time).
Right now I have a 10-GB hard drive (master) and 5-GB (slave) connected to my ABIT KT7-RAID's IDE 2 connector... the drives are older (1998-1999), so I assume they're ATA/33 or something. Anyway, I then have my CD-ROM drives (CD-RW master and DVD slave) connected to the IDE 1 connector. I believe that's how everything is supposed to be, as I've ALWAYS had it like this and everything's always worked fine. I don't use the RAID features (for 2+ hard drives), so I have the ATA/100 RAID IDE Controller disabled in the KT7's BIOS.
Now, enter new ATA/100 hard drive.
It is REPLACING my old hard drives -- not going in in addition (i.e. to use RAID features) -- so I will just have one ATA/100 hard drive, plus my two CD-ROM drives.
So how do I connect the new hard drive to use ATA/100? Does it just go back into the IDE 2 slot where the old hard drives were connected? Or do I leave the IDE 2 slot empty and put the new hard drive on IDE 3 or 4? (IDE 3 and 4 are the KT7-RAID-specific available connectors -- but I can't figure out whether they are supposed to be used for MULTIPLE hard drives in a RAID setup, or if I can just use them to plug in my ONE ATA/100 hard drive).
I assume I would then also have to enable the ATA/100 RAID IDE Controller in the BIOS? And would I still keep my CD-ROMs in IDE 1?
Any clarification/instructional help would be much appreciated. Thanks!
