How to connect a 120mm Delta Fan?
Baasha
1,989
20
Guys,
I just got a 120mm Delta fan (AFB1212GHE) and it's connectors don't seem to be the "normal" red/black/yellow cable!
There is a red/black/blue cable that connects to a 3-pin connector where the red/black go to a 4-pin molex connector and the blue turns into a yellow wire that connects to a 3-pin connector.
How on earth do I connect this fan?
I want to connect it to the PSU.
Please help!
Thanks.
Kelvrick
18,422
Sounds to me like its just options. Using the 3-pin connector to the motherboard or using the molex connecter going to the PSU and the yellow wire to the MOBO for optional rpm control/monitoring.
Baasha
1,989
20
Wait, so I connect the 4-pin molex (which has just the red & black cable) to a PSU 4-pin connector and the 3-pin connector to the MoBo?
I thought connecting this fan to the MoBo is dangerous because of the power it requires (12V @ 3.24A = 38.88W).
I have an Asus P6T7 WS MoBo and I do NOT want to fry it.
If I understand you correctly. you're saying the yellow cable that's attached to the 3-pin connector is just for the RPM control while the red/black connected to the 4-pin molex connector is for the PSU?
Tobal-G
Yes, yellow cable only reads RPM and won't draw any power from the motherboard. The power is coming from the red/black molex cable. You have to plug the fan to the molex cable to run the fan. The yellow "3 pin" cable is optional.
Baasha
1,989
20
I connected the Delta fan and bricks were shat.
I cut my finger! :(
The fan is also way too loud!
I suppose it could be bearable with a fan controller.
LOL! To think I was going to get 16 of these! LOLOLOL...
Rifter
751
its a delta what did you expect. I used to run 3 120mm deltas at 5500rpm in my old AMD duron computer. It sounded like a F14 at full military thrust.
Nocturnal
18,927
Definitely get a fan controller. I have nothing but Deltas in my PC but do use a fan controller. I use the Sunbeam fan controller.
Baasha
1,989
20
Cool... I got the Lamptron FC-5 V2 fan controller which also shows the RPM and is supposed to also be 30W per channel.
Its anodized black as well. :D
