I'm building a pc with some parts from my old machine and some new parts. My question is, how should I configure the IDE drives? I do have an ATA100 pci card with 2 additional IDE channels.
Here are my IDE components:
2 Lite-ON 12x burners
1 Lite-ON 16x DVD drive
1 Maxtor 7200 45 GB drive
1 Maxtor 7200 20 GB drive
I'd like to have the 20 GB drive be my system drive and the 45 GB drive be totally for storage.
Here's how I'll be using this computer
I will be doing video capture
I plan to do dvd ripping (I want to play around with SVCD creation for MY own use)
I will, at times, want to burn to both burners at the same time from the 45 GB drive (using diskjuggler or CDRWIN)
I will NOT be doing on-the-fly copying from either the CDR or the DVD drives
I will be doing a lot of downloading to the 45 GB drive
I will be playing a lot of RTS games (3D 1st persons make me ill)
I will be ripping my own CDs to MP3 (is there any program that will allow me to rip from both burners--or my burners and DVD drive--at the same time?)
I was thinking about having the following configuration:
20GB drive on it's own IDE channel (IDE 1)
45GB drive on IDE channel 2 as master
DVD drive on IDE channel 2 as slave
each burner on it's own IDE channel
What do you think?
The problem I forsee is when I add another storage drive in a year;would I then put that storage drive as a slave on IDE1?
What do you think?
