I have gleamed the following from Computer Audio and Stereophile sources:
First, the desktop needs to have a digital optical output called a S/PDIF. It further will need to have a high quality sound card, such as an RME HDSP 9652 Hammerfall DSP or the Lynx AES16. These sound cards use the ASIO protocol which allows the computer to bypass its PC audio handling altogether. If you add a PCMCIA based Firewire card, it needs to be compatible with audio, preferably using a Texas Instruments chipset. You connect the desktop to either an A/V receiver that accepts S/PDIF or highend DAC or even a Logiteck Squeezebox Touch which includes a DAC alllowing Wifi remote controlled or ethernet connected access to transfer 24 bits up to 88.2 or 96kHz. Finally, it has been recommended to use either Foobar 2000 or Media Monkey software to transfer CDs to desktop for playing on your 2 channel system. So has anybody tried this and did it result in better sound using transferred CDs than the sound of the CDs themselves in a pure analog system? Thanks for considering this query.
