Originally posted by: LOUISSSSS
^^ that is completely false. amd's are better at certain programs, intels are better at others. comparing single cores.. intel cpu's with the same exact components as the comparable amd system would rip dvd's faster than amd's and run photoshop better. amd cpu's would run those apps slower but run cooler and run a few(not all) games with higher fps. but gaming doesn't really matter with cpu, more or less video card
so are you telling me an AMD 3700($200) can even compare to an intel p4/xeon@3.6($400-700) or p4/xeon@($625-875) single core? google some benchmarks where the 3700 is even compared to those procs? highly doubt it..
i'm not a fanboy, just sick of all those who think amd processors are the best at everything, amd is still 1/2 the company intel is in value
READING IS GOOD....
He said you used to be able to....which is basically true...
Then he said that it no longer applies with the advent of the AMD 64
Originally posted by: HiME
thanks for the replies
as far as i understand is 64bit cpu only differs with the memory addressing, as it doesn't affect anything about clock speed. a 32bit and 64bit cpu's processing speed should be rated at the same way, is it?
my friend was like telling me that his A64 cpu was actually more than 2.2 Ghz while compared with 32bit cpu, i don't think he's right..
A Athlon 64 is a hybrid 32/64 bit CPU. So you can't really compare it just off that. 64 bit "mode" will only kick in if you have a 64 bit OS. The net gains tend to be small at this point.
If you could clarify better what you mean by a 64 bit CPU it would be helpful...do you mean a 64 bit CPU or a AMD 64. They are different as the AMD64 can run in 32 bit "mode"
Originally posted by: rod
If you want to compare an AMD and an Intel, you can get an approximate result by comparing the number of instructions per second (measured by MIPS).
P4's - 6 instructions/cycle
AMD64's = 9 instructions/cycle
Therefore:
3000MHz p4 = 3000 * 6 = 18,000 MIPS
2000MHz A64 = 2000 * 9 = 18,000 MIPS
So, a 3GHz P4 is about the same speed as a 2GHz A64 (So a 3GHz p4 = 2GHz A64 3000+). Otherfactors such as cache and memory controllers also affect performance, but in terms of raw power, the MIPS measurements are perfectly accurate.
RoD
Therefore:
RoD
Uhh... a 3200+ is 2 GHz... 3000+ is 1.8 GHz
Therefore:
RoD
I believe newcastle 3000+ were 2.0 GHz. I have a clawhammer 3200+ that is 2.0 GHz
Therefore:
RoD
The 754 3000+ is 2.0 GHz... Uhh... I might be wrong? lol.
Therefore:
RoD
http://geek.pricegrabber.com/search_getprod.php/masterid=2827542/
Therefore:
RoD
Socket 754..... 😛 😀
Socket 939 is a different story 🙂
He mentiioned nothing about socket 😉
Course it'd be implied socket 939.
Therefore:
RoD
Socket 754..... 😛 😀
