Hey Pingspike,
What is all this business about frying motherboards and your PC exploding if you breath on the wrong pins here?
It's true. And your dog will get fleas, and your cat will no longer land on its feet.
I've never even heard a anecdote of any of that happening
QED. Anecdote = true. Kid got a vaccine; kid developed autism. Therefore, vaccines cause autism. And, Jenny McCarthy says this is true.
Misuse of anecdotal evidence is a logical fallacy and is sometimes informally referred to as the "person who" fallacy
http://en.wikipedia.org/wiki/Anecdotal_evidence
Regardless, here are CMOS clearing instructions from manuals of mobos I have:
From my Tyan mobo's manual:
How to clear the CMOS data
- Power off system and disconnect power
supply from AC source (Tyan's emphasis)
- Use jumper cap to close Pin_2 and 3 for
several seconds to Clear CMOS
- Replace jumper cap to close Pin_1 and 2
Reconnect power supply to AC source
Power on system
Asus:
Turn OFF computer, unplug power cord
Remove the onboard battery
Move jumper pin from 1-2 to 2-3 for 5-10 seconds, then return to 1-2
Reinstall battery
Plug in power cord, turn ON computer
Note: do not move cap on CLR CMOS pins from default position unless clearing CMOS; doing so will cause boot failure. And your cat will lose its hair.
OK, I added the part about the cat.
Sticking a metal screwdriver into computer case while it is powered up: probably not a good idea for most people.
http://www.darwinawards.com/
In today's news, from ABC Medical:
http://abcnews.go.com/Health/P...tory?id=7788538&page=1
How dangerous could that laptop, desktop, or Mac sitting in front of you be?
Photo: ER visits due to computer injuries
The first report to count computer-related emergency room injuries shows that each year more and more Americans are tripping over cords, dropping monitors, banging heads and snagging limbs.
Of course, we should ban computers, for safety's sake.
And soda:
http://health.yahoo.com/news/h...usemuscleproblems.html
Drinking too much cola can increase the risk of a muscle problem called hypokalemia, experts warn.
The second pregnant patient, who'd consumed up to seven liters of cola a day for 10 months, had low potassium levels
Pregnant. 7 liters of cola. Pregnant. 7 liters of cola. Does not compute.
By the way: no proof that the cola dropped the potassium level: anyone who drinks 7 liters of cola a day while pregnant is ignorant of basic nutrition; really ignorant. K+ is a nutrient, found in fresh fruits and veggies: could be all that soda displaced good foods, and the low K+ was a secondary effect, not primary. (Lots of alcohol: low B vitamins, but, that is also nutritional generally, not a direct effect of alcohol: all those calories from ethanol, and you don't need to take in other foods and nutrients.)
There are ANECDOTAL reports of people frying mobos by powering up with CMOS in CLR position:
http://www.ocforums.com/showthread.php?t=77615
http://www.nvnews.net/vbulletin/showthread.php?t=125786
Interesting: Lenovo says to power up with the CMOS CLR jumpered for clear:
http://www-307.ibm.com/pc/support/site.wss/MIGR-52235.html
From 2006:
http://newsgroups.derkeiler.co.../2006-08/msg01049.html
If a user uses the clear CMOS jumper, with the +5VSB present, it can actually physically burn one of the two diodes inside the three-legged dual diode (K45 type). I have helped at least one person to repair their board after damaging it that way - they managed to solder two ordinary diodes in place of the burned three-legged device.
Therefore, since the design method for each clear CMOS implementation is unknown, but because there is a known design defect in a large number of motherboard types, it pays to unplug the computer so that there is no chance of +5VSB being present when the jumper is used.
So, in summary:
Loiussss can check his motherboard's manual, specific instructions will be there.
Missing jumper? Find one on old hard drive, or, use screwdriver to short pins.
Do this with the power cable unplugged.
Don't get tangled in your computer's cords or cables. If you do, and you hurt yourself, call a lawyer:
http://www.attorneyatlaw.com/2...dents-researchers-say/
You can get money for injuring yourself, because you left cables out and tripped over them.
And, if you stick a screwdriver into your powered PC case, you (or your heirs) might even get more, since there is no warning on your motherboard not to do that.
Take battery out when jumping pins? I do....others don't.
Your mileage may vary.
I am glad that we solved this.
Next: settlements in the occupied West Bank, the future of GM and Chrysler, health care (for computer injuries), racial and religious intolerance: having solved the CMOS CLR issue, we should be able to knock the rest of those out by Friday.
NX
