how to clean walls that use a water-based paint?
Special K
7,098
Does anyone know a good way to clean scuff marks off a wall that uses a water-based paint? This paint must be extremely cheap, because simply rubbbing water on the wall causes the paint to dissolve.
Is there any special solution that can clean walls that use water-based paint, without dissolving the paint in the process?
Mark R
16
There isn't really an alternative - use of water and a very mild detergent (e.g. sugar soap) and a soft cloth is best you can hope for. If the paint comes off, then you'll need to repaint - use a paint with a smoother finish (sometimes called 'vinyl' or 'silk') as these are less permeable to water, although they will still dissolve.
Special K
7,098
Originally posted by: BlackTigers
MAGIC ERASER!!!!!!!!!!!!!!!!!!!!
I tried that. You have to soak the eraser in water first. The eraser dissolved the paint when I rubbed it on the scuff marks. :(
Vette73
21,503
9
Face-Palm!!!
Its is water based, not water paint. In other words the water is juts a carrier, it is not the paint. The paint is latex and other items.
Sounds like a old and/or cheap paint when it was put on. Not much you can do. Also juts could be old paint as some early watre based non-lead paints were not that good as it was early tech back then.
Just scurb walls, prime, and put on a new coat of wal-mart or after rebate paint if oyu want to stay a long time.
Mark R
16
Originally posted by: paulxcook
Water-based paint on walls? WTF?
What else are you going to put on walls?
You're certainly not going to oil or solvent based paints on.
SagaLore
24,036
21
Wipe them off with a dry terry cloth. If they're stained, you're going to have to repaint - hopefully this time with a cleanable paint.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Sounds like the walls were never primed to begin with. Sand, prime, sand, paint, sand, paint or strategically place furniture/picture.
dsity
945
The apartment I lived in was like this. I tried to clean the dirty walls....and paint came off during the cleaning. NO way in hell i'm going to give up my deposit for such cheaply painted walls.
Special K
7,098
I should add that I live in what appears to be a cheaply and hastily constructed apartment complex. The buildings are only 1.5 years old but I am already noticing things that are cracking, flaking, etc.
I could just ask the landlord to send someone from maintenance out to repaint it, but I didn't want them to use that against me as a reason to not refund my deposit. If there's no way to actually clean the marks off though, I may not have any other option.
boomerang
18,883
641
Ummm, well you can. Just not over Latex paint.
DomS
Banned
Jul 15, 2008
1,678
umm....I've never heard of using water based paint on a wall
boomerang
18,883
641
Latex paint is water based. You clean the brushes, rollers whatever in water, right?
TruePaige
9,874
Indeed, Water based paint is very common for walls. Oil based paint is..horrid for many applications.
Special K
7,098
They do make water-based paints that are washable though, right? As in if you make a mark on the wall, you can clean it off with water and/or soap without having to worry about taking the paint off with it?
0roo0roo
64,795
84
yes, thats before it drys and cures. after that...it is like latex as the name implies..water doesn't really affect it. leave it on your brushes to dry and you'll be sad. sounds like his paint is just totally deteriorating and crumbling. best to scrub that off, prime and repaint.
Squisher
21,204
66
New construction often settles, boards dry and flex, imperfections appear. I wouldn't get too dejected about cracks in paint.
I have no suggestions for cleaning without water, though. It's pretty obvious they used cheap paint (maybe even watered down).
Mark R
16
Yes, a good quality water based paint will be washable. However, some surface finishes are more washable than others - e.g. true matt, or eggshell finish paint tends to be more susceptible to water than a semi-gloss paint.
Dec 27, 2001
11,272
I don't believe it is dissolving the paint. As I understand the pigment is just waterborne. As least that's the case with topcoat finishes.
