How to clean a Flat Screen Monitor??
wnangle
64
Like many, I retired my 22 Viewsonic 65 pound monitor and bought a 22 inch flatscreen a few weeks ago. Cleaning the screen on the old monitor was so easy, but I've heard all sorts of rumors about cleaning the flat screen. What is the best way to clean this type of monitor? Windex? Soap and water? Damp cloth? Dry cloth? Someone told me that I need to buy a $50 cleaning kit at the computer store to clean these monitors. Whats the real way to clean them? Oh, there is nothing spilt or sprayed on the monitor, just dust. I'am very careful not to even touch the screen.
Crono
23,720
1,502
Water and cloth. Just be careful you don't press too hard.
Welcome to AnandTech :)
AMDZen
12,589
Use a non abrasive cloth (made for glass like for your glasses) and a tiny bit of water. thats it
Kelemvor
16,928
8
If it needs more than just water, you can get stuff specifically for cleaning screens at OD or OM. Don't use Windex and the like because it can remove the coating that is on the monitors to keep the glare down and things like that.
Harvey
Administrator<br>Elite Member
67
Never use an ammonia based cleaner such as Windex. Ammonia is a killer for polycarbonate surfaces and anti-glare coatings used on many monitors, including flat panels.
effowe
6,012
18
They make wipes especially made for LCD screens that you can get at any computer store. They're just like the clorox or windex wipes, except they don't have any harsh chemicals.
sdifox
99,365
17,548
2 Microfibre cloths (you can get it from dollar store) + water. Wet one cloth, clean screen and wipe off with the dry one.
WildHorse
5,006
I use a mix that's 50% alcohol, 50% distilled water, on an old t-shirt.
Make sure the monitor is cool first.
xcript
8,258
I use Dust Off Monitor Wipes on my LCD and laptop display as I got a bunch for free. They do the job.
aidanjm
12,411
people say you shouldn't use Windex, but I use it anyway, it really cuts through the grease and grime :)
Spineshank
7,728
Are you cooking on your monitor?
Jun 14, 2003
10,442
damp cloth, with hot water .
i do have some cleaning solution and some microfiber cloths that came with it, but they are poor and leave streaks. untill, that is, i cleaned the screen immediately after switching off. the heat of the monitor would evapourate the cleaning stuff nicely and leave no marks.
I Saw OJ
4,923
I had a lady here at my work clean her LCD screen with hand sanitizer lotion...
*facepalm*
aidanjm
12,411
no, but occasionally people touch the screen, which leaves greasy smudges
Linflas
15,395
78
Those people need to have that finger broken so they can learn what a vile habit that is.
MrBond
9,911
The ammonia in Windex will cause the anti-glare coating to yellow I've heard.
I bought my Thinkpad used from eBay and when it came, the screen is tinted a light shade of yellow. I'm guessing that's what the seller did before sending it out, not knowing any better.
It's kind of annoying, but I'm not doing anything on it that requires super accurate color reproduction anyway. It still keeps me from using Windex on my 2001FP.
