I have an A-Bit IS7 and I was planning on having a gigabit switch in my dorm room at school for quick file transfers between my laptop, desktop, and server. I have been seeing my network connections display "3Com Gigabit NIC" for the past year now so I thought I have a gigabit controller. Then as I'm cleaning my room I stumble across my motherboard box and it says 10/100 Ethernet controller. I check the manual and it says the same thing as the box. I check newegg(where I bought it) and it says 10/100. Yet everywhere on my PC says Gigabit.
So I decide to install the NIC diagnostics that came with the Motherboard. It tells me lots of stuff most importantly the "Media Type" which it reports "10/100/1000BT"
So I'm thinking that I do have a gigabit. OR I have a gigabit that has been nerfed. Is there anyway I can find out if I do have gigabit or not before I get the switch and try the transfers? Because if I don't have Gigabit then I want to buy a NIC for that when I buy the other networking items.
Thanks in advance
Thanks in advance
