Question How to check/monitor PSU for hours?
drthrd
54
My computer is freezing up. I have checked my memory now I need to check my PSU. I was thinking about getting the Thermaltake Dr. Power II tester. But that does not constantly monitor the PSU. Is there a tester that will monitor your PSU constantly and show any abnormal voltages and currents?
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
You get a different PSU. One that supports monitoring with logging.
VirtualLarry
56,587
10,225
Hey JG. I posted a thread once suggesting that the ATX spec should be revised, to allow using the unused -5V (or -12V) lines on the ATX 24-pin connector, as I2C data channels, to allow bi-directional communication between the mobo and the PSU. What do you think? It would be a minimal increase in cost for system-integrators (no separate USB cable), and I have no idea what additional costs the PSU maker would entail, for a control board, or integration with the existing control board in a PSU.
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
Instead now Intel has eliminated all but the 12V and left all other voltage regulation to the motherboard. Go figure.
