Originally posted by: LOUISSSSS
i have speedfan, i get a reading of 2100RPM (is that the correct speed for the tuniq fan?) is that the MAX speed for it? how can i control it using speedfan or any other program.
I am not having any luck controlling the Tuniq fan speed with software (played around with speedfan a lot) but the manual rheostat that comes with the unit does a decent enough job.
Some system "quirks" to be aware of - if you have your BIOS set to control the CPU fanspeed based on thermal feedback THEN set the manual rheostat switch to "high".
Example - if the BIOS determines (how ever it does that) that the fanspeed needs to be 1100rpm based on current CPU temp then that is the max you can dial the Tuniq to do with the rheostat is 1100rpm when cranked to "high". On the flip side you can dial it down as low as ~280rpms.
So the BIOS and the rheostat work in series.
Alternatively you can just plug the Tuniq power cable into a molex, in which case it will be running flatout maximum (>2000rpm) when the rheostat is set to "high", and naturally you can dial the rpm's down from there.
(I confirmed this by wiring the yellow "tachometer" wire to a mobo fan header and monitored with speedfan while the red/black power/ground lines were connected to a molex)
