How To
How to Change Accessibility Settings in Mac OS X
‘Accessibility’ in Mac is an assistive feature that augments the interaction between users and apps. A wide variety of features like screen and cursor magnification, voiceover, visual flash alerts, etc. enhance accessibility of applications for a disable person, and consequently, broadens the user-base. Here’s how you add an app to the Accessibility option in Mac.
Step 1
Click ‘System Preferences’
Go to the Apple menu or the dock and click ‘System Preferences’. Consequently, a pane opens up at the centre of the screen.
Step 2
Select ‘Security & Privacy’
Click on the ‘Security & Privacy’ icon from the multiple icons displayed on the pane. A panel will open up.
Step 3
Select ‘Privacy’
Click on the ‘Privacy’ tab from the panel. A list of options will appear on the left side of the panel.
Step 4
Select ‘Accessibility’
Browse through the list of applications and click on ‘Accessibility’. It gives you the access to the settings of ‘Accessibility’.
Step 5
Click ‘Lock’ Icon
Click the ‘Lock’ icon situated at the bottom left corner of the panel. A box will pop up prompting you to enter 'Administrator’s Password'.
Step 6
Select ‘Unlock’
After logging in the 'Username' and 'Password', click ‘Unlock’. This will unlock the settings.
In this way, you can easily change the Accessibility settings from System Preferences.
Status
Not open for further replies.
Status
