<< you get calipered, or get ultrasound readings, or get tanked (as in displacement)
You cant get a measurement from the internet any more than it will do your laundry >>
The latest toy/tool actually is more convenient than that. You take off your shoes and socks and stand on some stainless plates on a scale type device. It measures the resistance to calculate your body fat %. Pretty accurate too, from what I am told by the specialist using it.
I was participating in a job fair, at our hospital, put on for some upcoming HS graduates looking for carreer options.
JMaster your ideal body weight is about 165 pounds.
IBW (male) = 50kg + [2.3 x (inches over 60)]
kg x 2.2 = lbs
