How to adjust monitor geometry & sizes to be perfect?
pay
1,401
I have a Sony GDM-FW900, its the 24" Trinitron Widescreen (16:10) and I always hate adjusting geometry and sizes on the monitor, I can never get the image to be centers, straight and perfect. Does anyone know if there is an easier way, maybe a program, to automatically align the image to perfectly fill up the entire screen? By the way its running on a Radeon 9700 @ 1920*1200 @ 75Hz
Thanks
Vadatajs
3,475
AFAIK there isn't, you have to manually set your monitor for every resolution/refresh rate. You should only have to do it once, however, your monitor should remember the settings if you change resolution (mine does anyway, not a sony though).
