How to adjust FAN speed on GA-DS3
Herradura
137
Im confused on what settings to use when in BIOS so that I may be able to adjust fan speeds in windows.
If you can just state which setting I should put these on that would be great
(SMART FAN METHOD)
Auto
Intel (R) QST
Legacy
Disable
(SMART MODE)
Auto
Voltage
PWM
_________________________
Also what is the best program to use when playing around with FAN speeds?
Thanks, Kenny
Herradura
137
34 veiws and no reply :( cmon guys, Im sure one of you know how to do this. Alot of users have this board any reply can help :)
Herradura
137
Once step closer :) thank you.
Now that I know to set the method to legacy I assume I set the smart mode to PWM but I still dont know how to control the fan while in windows.
