Easier than that. Simply make a file called "whatever.rdp" and put it on their desktop with the following contents. Windows recognizes the .rdp extension as a remote desktop template, and will connect when you double click it.
screen mode id:i:2
desktopwidth:i:1024
desktopheight:i:768
session bpp:i:16
winposstr:s:0,1,0,0,1388,1009
full address:s:IPADDRESS
ORT
compression:i:1
keyboardhook:i:2
audiomode:i:0
redirectdrives:i:0
redirectprinters:i:1
redirectcomports:i:0
redirectsmartcards:i:1
displayconnectionbar:i:1
autoreconnection enabled:i:1
username:s:USERNAME
domain:s:YOUR_DOMAIN_IF_ANY
alternate shell:s:
shell working directory:s:
disable wallpaper:i:1
disable full window drag:i:1
disable menu anims:i:1
disable themes:i:0
disable cursor setting:i:0
bitmapcachepersistenable:i:1
This can easily be generated by running mstsc, hitting options, filling them out, then hitting "Save As"
