How to add Dos (FAT32) after WinXP (NTFS) is installed?
zhena
587
So I have windows xp installed on a hardrive with NTFS.
I want to add Win98 DOS in a FAT32 partition.
The problem is what steps do I need to take to add it to the winxp bootloader?
The way I usually do it, is make a small primary partition formated with fat32 which is
active and bootable, and then let the winxp install create the other ntfs partition, and setup the bootloader. At the end in the boot menu I have Windows XP and Win98, since i am using 98 version of command.com
In this case I have Windows XP already. I don't want to use an external bootloader, it must be possible to create a partition with fat32, sys it, and make the default xp bootloader recognize it?
but how?
zhena
587
calvin I have no idea which guide on bootdisk.com shows me how to do that... i looked around
zhena
587
basically i need to get the right bootsect.dos file..
but i where and how do i get it?
Woody419
770
Look like this is a job for TweakHome PC
The site has all the step-by-step instructions for dual-boot systems including installing a Win 9x after an NTFS OS.
Com807877
230
Not entirely sure what you're asking. If you want to convert FAT32 to NTFS you can go to the command promt in Win XP (Start menu -> RUN -> Type "CMD" enter) Then type "Convert <drive> /fs:ntfs" to convert your drive.
