How the hell do I remove a car door panel? window motor failure
Ogg
4,829
$276 to replace a power window motor and regulator from the dealership :|
I can buy the motor for $75 but Ive not found a regulator. Hell I dont even know what it is :eek:
I guess my goal of do it yourself is up in smoke............:(
Roger will you come over and fix it? Please
fredtam
5,694
What kind of car? Some are extremely hard to change.
Ogg
4,829
Yeah theyll sell me the parts.
They sell the motor/regulator for almost $200
Motor from autoparts store $75
----->2000 Hyundai elantra wagon
NeoPTLD
2,544
Every car is different. Usually, it involves locating hidden fasteners or pop in tabs and prying the panel off.
MattCo
2,198
First, buy a book that has the detailed schematics of your car ( like chilton). It will tell you exactly what to do. You will probably need a panel remover tool and some replacement panel fasteners when you break a few.
-MC
Ness
5,407
Go to your local autozone and purchase a Haynes manual on your car. It will do you much good both here and any other time you need help with your car.
I believe they cost about 15-20 dollars and have very detailed diagrams of everything in the car.
They will both tell and show you how to replace this part.
Ogg
Typical window regulator, the motor attachés to this assembly.
Remove door panel
Remove plastic sheathing
Locate 10mm bolts holding regulator/motor assembly in and loosen them
Clamp glass o door using plastic spring clamps
Remove 10mm bolts and slide regulator/motor assembly out through access panel in door
Assembly is reverse of removal
What part of the world do you live in
:p:wine:;)
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
I have had the morots fail. those can usually be replace with the loss of a couple of knuckles. A pro (Roger) may be able to do it withou any loss of skin.
Regulators are harder, depending on the location.
I had a auto glass shop replace one for me for $60 labor and I supplied the parts. Part was shipped from a recycler (junk yard) across the country for $50.
Ogg
4,829
Originally posted by: Roger
Ogg
Remove door panel
:p:wine:;)
Aahh so thats a regulator
Im far far away ole buddy, down in the swamps of south Louisiana :(
If I could just get the damn panel off
thanks guys for all the info. Im gonna buy a manual for my car and a big hammer!!!:p
Chadder007
7,560
Wait wait....so this is not covered under the 10 year warranty??
Ogg
4,829
5 YEAR 60,00 MILE
BUMPER-TO-BUMPER COVERAGE
10 YEAR 100,00 MILE
POWERTRAIN PROTECTION
<--------65000 miles :(
MrScott81
1,891
5 YEAR 60,00 MILE
10 YEAR 100,00 MILE
:( sorry to hear that....My mom has an elantra and that happened to her too, but she was still under warranty, which is why i asked.
why isn't your car still under warranty?
You sir have a BIG MOUTH.
huh?
fredtam
5,694
After you fix it keep an eye out for recalls (if there isn't one). I had the dealer replace the regulator on my 2001 Altima and 2 weeks later I got a recall letter saying that all four would be replaced for free. Nissan reimbursed me for the one I had gotten replaced already. I say this because there seems to be a lot of people experiencing the same problem with that car.
