How synchronize files between 2000 and XP Pro?
MedicBob
4,151
Ok here is the deal, I want to sync certain folders in a data partition on my laptop with the same certain folders on my main rig. How do I go about doing this?
I know I can manually do this. Why is two fold, one to back up the Laptop/Data, two to make transfering files, etc. over with out having to cut and paste.
Any help? Both have all the needed protocols and can share over the network. I can transfer files etc. When I try to use the synchronization setup it only allows my IE home page.
Thanks in advance, I will also be posting this in networking so don't remind me about double posts please.:D
Bob
Bglad
1,571
Why would you think that saying you know it is wrong to post in 2 places would make it alright?
You have 3 choices.
1. Use a briefcase for manual updating.
2. Use an offline folder that will update itself.
3. Write a script to update the files.
