- Jul 17, 2010
- 2,140
- 3
- 81
I have just bought a WD Blue 1TB 2.5" SATA HDD, WD10SPCX. I bought the Blue because I did not want it to spin down like the Greens however this thing spins down far more aggressive than my 3TB Green 3.5" I bought a few years ago. Sometimes it takes only a couple of minutes to spin down.
I have contacted WD who say there is no way for the user to disable the spin down.
I did read on a thread on this fourm where a user on this forum found a way to disable the spin down? Not sure if that only applied to external though.
Disabling turn off drives after x minutes in power settings in control panel does nothing.
Does anybody know if there is a way to do this? I am pretty annoyed by this. Had I known they had put this aggressive power management nonsense in the Blue's as well I would have got a Black.
