- May 28, 2009
- 555
- 2
- 71
Watt is Useful
Most really meaningful and intuitive units in physics describe the relation to time: bit/s, mph, Hz. Yet, not all of these unit names explicitly spell out this wonderful relation and sadly neither does watt. Power measured in watt is in fact energy divided by time, it's that simple. Why - I ask you - have we then still people start vigorously converting kWh to years to dollars, when the capital W conveys all that needs to said already? Whatever the reasons may be, there is a simple calculation that you can do once, right now and astonish people around you when this topic comes up for the rest of your life.
Your Own, Personal Power Coefficient
Once you know what 1 W costs for the duration of a year, you'll never need to convert units again, except when watts handily turn to currency when you multiply W with a simple coefficient (multiplier).
1 year consists of 8766 h.
1 kWh costs about 20 cents (22.8 cents is more like it after tax).
Assume 24/7 use. You can always easily divide this to get your 12h working day or any other usage model.
Q: If you burn 1 W or in other words 8766 Wh/year (8.766 kWh/a), each costing 22.8 cent/kWh, how much does 1 W cost for the duration of a year?
A: 8.766 * 0.228 = 1.998 dollars a year (or €/a)
1 Watt = 2 dollars/year
Amazing!
Calculate your own personal power coefficient by replacing your regional prices and adjusting for any part of 24 hours use. Once you know that your legacy 6W clock radio costs you 12$/a, you'll think twice before you'll leave it plugged in the wall, that's how your personal coefficient saves power, the tried and true method of raising awareness.
So, what is your coefficient?
Amazing!
