- Aug 11, 2000
- 10,079
- 0
- 0
After three generations, I think I've designed an amplifier module that works. Based on the LM3875, it's a traditional "gainclone" amp, with the following features:
-30w per module. (These things are great for bi- or tri-amping.)
-Low cost - I can keep the cost as low as 10$/module for parts and PCB, although this is only if I buy in bulk.
-Size - these things are about 2.5" x 1.5" x 1". Of course, you need a heatsink, which makes it much bigger.
-Quality - these amplifiers, if built right, can have a THD+N of well under 0.1% through 20khz. To give you a rough idea, most amps have a THD+N of 1-2%, and car amps can be as high as 5%.
Anyway, I can manufacture either kits (add your own PSU/preamp), "complete" kits (includes PSU without transformer), "deluxe" kits (includes simple stepped attenuator or potentiometer for use as passive preamp), and "Super Deluxe" (includes PSU, preamp PSU, attenuator, and class-A transistor buffer).
I could also make completed modules, or just sell the amps ready-to-go.
There are, however, a few quirks.
1. No protection, so if you're not careful, you can drive your amp or speaker to clipping pretty easily. Unless you're careful and/or know what you're doing, you can fry the amp.
2. Not super-high-power. These are rated into 56 watts max into 4 ohms, but most people get no more than 30. As a result, you can't drive your Martin Logans.
3. Amplifier "hum". Gainclones seem to be extra-sensitive to just about everything. I put my PSU in a seperate box entirely.
NOTE:
Gainclones do NOT require fancy-pants cables. Cat5e is the reccomended speaker and interconnect wire, especially the shielded stuff. That said, I'm just going on what I've heard - I use zip cord.
So, what do you think I should do? I'm about to make another prototype PCB, which is essentially a re-worked version of the 3rd generation design that does'nt need a jumper, and seeing as how the 3g amp worked (though I accidentally cooked the chip I had in it), this one should work even better. A kit (two mono amp modules) with PSU parts would be about 40$; a completed and assembled amp (ready to go) is about 120$-250$ depending on what you want in it.
NOTE:
