Originally posted by: Mark R
Basically, connect one switch so that the positive connects to its 'common', and connect the other so that the negative connects to its 'common'.
Then you build a grid - connect the rows to the 'positions' on one switch and the columns to the 'positions' on teh other switch.
Connect a bulb from each column to each row (5 rows, 5 columns = 25 bulbs).
Ok, I see that now. You need the bulbs between the switches:
[*]Live -> Switch -> Bulb -> Switch -> Neutral.
I was trying to do it with the bulbs after the switches:
[*]Live -> Switch -> Switch -> Bulb -> Neutral.
And of course, I couldn't figure it out. Thanks for the help.
I ended up doing something similar to what you posted above with decoders and MOSFETs. The devices are in three rows of 8, with one extra. So instead of two decoders which are 4->16, I got three decoders which are 3->8. That way, I can just dial in the row and column. I hope they work. If not, it was a $1 total investment for the decoders.
I also looked around, and those MOSFETs that you linked appear to be right near the cheapest, so I ordered those exact ones.
I have one question though. Do decoder input pins and MOSFET input pins need to be connected to ground through a large resistor? I've worked with logic gates a little in the past and they needed to be grounded to function. Thus, I assume these components will also need grounding. Is that assumption correct?
