- Nov 18, 2001
- 13,234
- 2
- 81
I'm considering upgrading my current case fans (Antec Tri-Cools) to the PWM Cougars that are on sale at Newegg today, but I'm not sure of the best way to control them. I have an ASRock Z68 PRO3 motherboard and looking at the manual it appears that I have 2 CPU fan connectors and 1 "power fan connector". I have 4 spots for 120mm case fans and I'm considering filling them all, along with the fan on my heatsink (Scythe Mugen 3).
So, how do you think I should control the fans? Do the PWM splitter cables work well? Is it easy to make a custom fan profile for them or will the motherboard/BIOS try to control them all along with the CPU fan, which may result in weird speeds given that the CPU fan is completely different. Should I replace the CPU fan as well? Should I buy a separate fan controller?
These are the fans I'm looking at: http://www.newegg.com/Product/Produc...82E16835553002
