Instead of that, it may be a little plastic filter housing clipped to the wall of the underbody at rear of car, fairly close to the fuel tank. If it was really inside the tank it couldn't be serviced.Originally posted by: nakedfrog
As far as I can tell, mine is part of my fuel pump, which is in my tank. There's nothing in the manual about when it should be changed.
A ridiculous design to be sure.
Originally posted by: d33pt
for my car..manufacturer does not have a recommendation. it is a real PITA to replace mine so i haven't replaced it at 200k. seems ok, but i really should do it sometime soon. I get dirty gas sometimes too.
Originally posted by: DarkManX
How often would you replace your fuel filter? my owners manual says "to replace it when clogged" my buddy went through several manuals that dont even mention it. I think its a pretty important and cheap thing to take care of every 15,000 miles or so.
