Shouldn't this be in Highly Technical?
Its your favorite tech again, don't sue me
Ok, really quickly, as I am in a rush. If you change your fluid, do it acording to the manual if you have a late model car ( built since 95 or so ) if before, do NOT chage it. Here is why:
That ATF ( tranny fluid ) isn't really a oil. It is a friction modifier. at low speeds, at acts as a lube. At high speeds, it actually helps the clutches and bands in your tranny "bind" or stick together. When your tranny wears, the ATF wears with it, breaking down into basicly water. If you change your fluid on an old vehicle, those clutches do not want to stick together, and the friction coating on the clutches begind to actually stick to the "steels" between the clutches, and then your tranny will not stay in gear. Time for a rebuild.
If you have a new car, chage the fluid according to the manual as long is it is still RED in color. If it changes to brown, you over heated the fluid, and as soon as you chage it a bunch of the friction coating is going to come off the clutches, and clog the filter. Instant rebuild.
And for everyone's knowledge, I have NEVER chaged the fluid on ANY of my vehicles. One is a ford econoline van from 1985, with over 800k on it. ( only 7 engines so far ) I use it for delivery of computer stuff all over
More knoledge: 30k to 50k is what is listed in most manuals for ATF change. If you do decide to chage the ATF, make sure that the company removes the fluid from the converter. It can hold up to 1/2 of the fluid in a trannny, up to 2 gallons.
