How often do you get a lemon hard drive? I think I did! Please Help!!!!!
BPiersol
120
My dads computer had a power surge that fried a chip on his old HDD. It was a Quantum Fireball 6.4 gb. I found and purchased him another one (same kind and size, brand new). I ran Fdisk, partitioned it, and installed Windows 98. I then installed his video, modem and sound drivers. Everything was great for about 30 minutes, when I got a big blue screen that saidDisk Write Error- Unable to write to disk in drive C: Data or files might be lost. Press any key to continue. Then the HDD made some noises (like clicking or popping) and my computer pretty much froze. Well, I rebooted but it gave me an error message saying that drive C wasn't partitioned. I rebooted again, and got into windows for about 3 minutes and got the blue screen again. After this happened, I pulled the pc apart and took the HDD out. Now it sounds like a ball bearing is loose inside of it.
I contacted Maxtor's warranty service and they're shipping out a replacement. My question to all of you is this- Do you think I just got a bad HDD, or do you think I have some other problem? The pc is a Compaq 5440 AMD K-6 2 450 mhz. The bios has been re-flashed with a newer version from the motherboard manufacturers website (so I guess it's not a Compaq pc anymore!). The mobo is a Gigabyte GA-5SMM.
bozo1
6,364
Definitely a bad drive if you hear something rattling around in it.
BPiersol
120
Thats what I was thinking, too. But I kind of wondered why it did that after about a half an hour of actually using it. The hard drive worked for about 1 1/2 hours before it died. It took about an hour to partition and install windows. I then used the pc for about 30 minutes. Doesn't that seem strange? Or is there some sort of burn in period that it didn't make?
compudog
5,782
I've gotten two bad (consecutive) hard drives from Western Dig. The first worked for about a week. I RMA'd and got a second rpelacement drive and that didn't even get through the OS install phase. The third drive was the winner and is still running fine.
