How o communicate with Linksys wireless router
karma4jake
I have a Linksys 54mg G router running off a DSL 1mb line. After you use the CD to make the initial settings through a wire connecton how do you get back in to make changes. There doesn't appear to be any kind of program installed and if I run the CD again it gives me some junk about not being able to do it. So I have to unhook it and reset the router then go through the setup agian. Seems there should be a program or setting pannel to change the SSID and security settings. The Linksys notebook adapter that I got has a program that runs all the time in which you can change settings to the card such as SSID and security.
use your internet browser and type in the IP address of the router in the address line, that will get you back into setup.
