how muhc power do i need?
twitchee2
2,135
how uhc power do i need for 4 case fans,1gb of RAM,a8n-sli,single 6600gt,64 3200+ 2.0. i need to know how much and by what brand(i would like to expand to dual 6600gts and 4gb of ram).
Hyperlite
5,664
i'd say a good 500w at least, but buying a PSU isn't that simple...you have a beastly rig, so i suggest getting a high end OCZ or Enermax psu, or mabye an Ultra X-Connect. if you don't want to spend an arm and a leg, the Fortron 530w is a great option also.
JBDan
2,333
Pricey but the best in my opinion> PCPower&Cooling > then come OCZ > Antec > Fortron
ts3433
2,731
Don't bump your thread after just 7 minutes. Give it a couple hours, at least.
If you plan to just go 6600GT SLI you probably don't need a big 500W. Try an Enermax, Seasonic, or PCP&C Silencer (their lower-end units) in the 400-460W range. Just make sure the rails (especially the +12V) have all the amperage you need--looking at these is a lot more important than the oft-misrepresented wattage values.
