- Jan 23, 2007
- 1,393
- 379
- 136
Short Version:
2 questions:
1) What is the typical relationship between underclocking a Radeon and maximum power Wattage draw? For example, if I would underclock it 10%, would that lead to 10% less wattage use?
2) Is there any way to make this simple and repeatable on bootup?
Long Version:
I'm in a situation where I have a SFF Lenovo desktop PC, and would like to upgrade the video from the onboard Intel HD graphics. Since it is a small form factor PC, I am limited to half height/low profile cards.
I presently get a 3Dmark Sky Diver score of 951 on it. For 95% of our casual games, this is fine, but I'd like to be able to do some with 3D.
From what I've read, this PC is limited to 45 Watt video cards, so I initially thought I would be limited to tracking down a 30 Watt GT 1030 card for it, which gives a G3Dmark score of ~ 2,200.
However, then I noticed that the Radeon RX 550 uses up to 50 Watts, and gives a G3Dmark score of 3,400. I found myself wishfully thinking, "Hmm, if only I could get that wattage down by 5 watts or more, I could
use the Radeon in my system. I recently found a used Radeon Pro WX 3100 low profile card for a decent price. Evidently it uses the same core as an RX 550, is within 3% of the same specs, and has the same 50 Watt
power use ceiling. I'm wondering if I might be able to use the gaming drivers that are available for it, underclock it 10% to 15%, and end up with a much more capable card than the GT 1030 I thought I would have to
make do with. Of course, I would need to make certain that it automatically does this on bootup each and every time, and I'm not sure there is an easy way to accomplish this.
If anyone has previously underclocked a Radeon card in order to decrease Wattage draw in a similar manner, I would be interested in hearing your experience. Thanks!
2 questions:
Long Version:
