How much water do I have to drive through to f*** up my car?
LuckyTaxi
6,044
23
Major stormed moved through PA today and of course there was a part of the road near my office that was flooded. If I had to guess, the water came up maybe halfway to my tires. You figure, the motion of the water and the splashing from the cars coming from the opposite direction, it was much higher. I wasn't the only one going through this and there was a long line of cars waiting to pass through this pool of water!
Now I'm worried that the car may not start later this afternoon.
LuckyTaxi
6,044
23
i assume if it hasnt stalled out going through it, i should be fine. hopefully
BassBomb
8,390
yea, as long as it isnt starting to choke on water
best is to keep off the throttle if you are going through something like that so it doesnt suck in the water
Demon-Xanth
20,551
It varies widely based on the car itself. In my case, I would have to have water up to my turn signals before the engine would pull in water, but by that time the carpets would probably be ruined.
ayabe
7,449
If you didn't stall then you're fine, especially because everything will be dry by the time you go home.
I stalled out my GSR once going through a puddle err lake...once. Rolled out of the puddle, let it sit for a few mins and it fired right up without any issues.
bruceb
8,874
111
Good rule of thumb is to go very slowly thru any deep water. And unless you have a high vehicle (pickup, jeep or similar) I would avoid any water over 4 or so inches in depth.
HarryLui
1,518
33
I've seen couple cars trying crossing puddle fast and stalled. All other slow moving cars pasted just fine.
StageLeft
70,150
Intake is most important but I think you can have issues if you drown the exhaust, too.
BW86
13,114
30
I don't think drowning the ehaust would stall the car - atleast my boats don't stall and they're exhausts are always under the water. :hmm:
JDub02
6,209
Not necessarily stall, but it can put alot of additional backpressure on the exhaust. If the motor does stall, the water will flood the exhaust making it nearly impossible to start. Your boat exhaust is designed for water. I'm sure it's angled down so water can't flood back in and the motor is probably designed for the additional backpressure.
My only experience is with Jeeps playing submarine. :) Gotta love snap out carpeting and drain holes.
exdeath
13,679
10
Carpet? *Real* Jeeps don't have carpet! ;)
JulesMaximus
74,567
969
LOL, still funny here!
Anyway, the best advice is to avoid driving through water at all. Unless it's "life or death" wait it out and let the water subside.
Agreed. That much standing water can quickly become moving water and then you are in a world of trouble.
JDub02
6,209
I know. It was trying to be somewhat civilized. Rolling down the road on SS Boggers kind of negated that, though. I've never heard tires that loud.
StageLeft
70,150
If it's crazy cold and freezes around the exhaust before you pull out it will!
SoulAssassin
6,135
I've done at least 30, probably 36, inches of water routinely in my Jeep. Soaked the distributor cap once and it died.
These are all on stock 30" tires before I lifted it, luckily no issues that day as it was in February:
http://picasaweb.google.com/lh/phot...?authkey=Gv1sRgCODGiPrM78WOVw&feat=directlink
Not much deep water on this but still a cool vid
Raduque
13,140
138
My dad tells stories about driving down flooded roads in his Camaro with sidepipes when he was younger and making the water bubble. Of course, that car had a carburetor so the water would have to be well above the mid-fender to stall it out.
lurk3r
981
I've had my old Samauri thru water that was ankle deep in the driver's seat. Your biggest issue will be electrical, most of your drivetrain should be reasonably well sealed.
JeepinEd
869
63
I've had water rushing over my hood, but then that was in a Jeep.
The one thing nobody has mentioned, though, is that (AFAIK) most differentials have a breather hose. It's quite possible for water to get sucked into the car's differential and cause problems.
Most Jeepers relocate or extend the hose, but I have never really noticed how normal cars are set up.
iamwiz82
30,772
13
Transmissions, as well. I have blown up an engine and a transmission in high water.
It's not good to find mud in your heads :D
